Super cali
- Messages
- 4
Hi all,
We have a 2015 Beach. The drivers door window button is not responding when I press it to get the driver window down, but does respond when I want it up. It does not feel like it's 'engaging' - i.e. completely dead- when pressed to put window down. Once the window is down, (by using remote key) I can pull on the door button to get the window up. When I use the remote key, I can press the 'unlock' and 'lock' button to get the window up and down. I can operate the passenger window from my drivers door buttons no problem. Does this suggest it is not a fuse? I've wiggled the rubber thing between the door and van as others suggested, and tried the remote key thing too, but no luck.
If it is a fuse, I'll have to post another question, as I've confused myself by reading too many bits on here as to whether this fuse would be in the 'dash' under my drinks holder - I got it off and had a look - phew - or under the passenger chair. Again, had a look and said mmm. Thought I'd ask here before heading to a garage in case the answer is obvious to someone. Thanks so much in advance.
