Electric Coffee Machine for Cali
D
Davidandbev
Hello again, any recommendations on a good compact electric coffee machine, as we do like our coffee.
Fingers crossed we should be getting our van next week.
Thanks, as always B & D.
You probably want to look at @CaliforniaTime videos on YouTube. Will has tested lots. My own coffee addiction has been sated by a small cafetière (£5 from Waitrose), and coffee bags.
And good luck on getting your van next week - probably want champagne instead of coffee?
And good luck on getting your van next week - probably want champagne instead of coffee? lots of champagne for sure followed by strong coffee the morning after
Check out the coffee thread on here.
It started in 2014 so go towards the last few pages.
I have an AeroPress for the morning latte with a Nespresso plug in frother. Just flat milk if off grid. For a quick espresso I use the Wacaco pump. Both work great, compact and more importantly easy to clean up after.
Got one of these for sale if interested, was fantastic in the T6 and took up no room.
This is what we have - with the larger water tank. You have to be a bit organised to do two coffees (grounds can get a bit messy, but I don’t like using nespresso capsules, though they are an option). We then use a stainless steel jug with plunge frother to heat and foam milk.
Together they result in excellent latte, as seen here when we were marshalling a race2488E5F7-1D2F-473E-92DB-C66E6F6D2F56.jpeg
When were on hookup, we use a Nespresso Essenza Mini and a milk frother. Takes up very little room, makes great coffee. Sachet flat whites and cappuccinos when not on hookup!
I had one of those wacaco machines it works well but a bit finicky so when I got my EcoFlow lithium battery I decided to buy a Delonghi coffee machine the smallest they have and it fits on the floor behind the drivers seat . Perfect so now it’s coffee and a toast in the morning…
