Got to be a connection issue at ECU or at van socket. Have you tried a nearby ECU?My 3 pin socket has stopped working. RCDs on campsite feed and in my van are not tripped. Any ideas to save a holiday
1. When on EHU do you have a Plug symbol R lower on the Control Panel ? And is the Control Panel voltage over 13.4 v?My 3 pin socket has stopped working. RCDs on campsite feed and in my van are not tripped. Any ideas to save a holiday
2. If the above is NO then no power is getting to the van.
This means the Campsite connection is dead, your lead is defective or the RCD in the Campervan has failed.
Try another EHU socket.
Try another lead, that you know is working.
Thanks for your tesponse. Using your advice I have eliminated the campsite and my cables so it must be the RCD in the van. Do you know how I might source one?1. When on EHU do you have a Plug symbol R lower on the Control Panel ? And is the Control Panel voltage over 13.4 v?
cables ok. campsite pillar ok. no symbol on display. trip button on rcd not working. must be the rcd. do you have any idea how i might source one? many thanks.Got to be a connection issue at ECU or at van socket. Have you tried a nearby ECU?
might have a loose/dropped connection. Isolate power and check cables are secure into connections. If confident to do so with hookup connected check for 230v L&N on incoming terminals.cables ok. campsite pillar ok. no symbol on display. trip button on rcd not working. must be the rcd. do you have any idea how i might source one? many thanks.
