Z
zidz
Hi all,
My friend bought VW GC 600 2022 and has some question regarding to electricity.
Thank you for your help
With best regards
Zdenek
- Fridge
- There is a classic problem that if fridge is on battery is drained off in max 1 day.
That is the main problem.
According to previous owner battery has been replaced and fridge too in terms of warranty so the problem is there from begining.
From the forum I know that battery should cover 3 - 4 days, is it correct?
My friend supposed that it is power regulation but everytime when he set e.g 2 lights only, closes and reopen fridge again (e.g. after 1 hour), there are all 5 lights on again..
Is it correct? What purpoise is the button in the fridge with 5 lights for?
- Battery charging
- Could I ask you for your experiences regarding to battery charging? How many kilometers / drive time is needed to fully charge the battery (with / without booster)?
- Battery boost
- Are there any recommendation regarding to battery booster? Can be used often / anytime without any restriction?
- Battery change
- Did anyone change the battery for e.g LIPO? Are there any other changes necessary (e. g. voltage converter, charging system...)?
- Additional battery
- Did anyone added another AGM battery? If so where is the best place to place/connect it?
With best regards
Zdenek
