Azamat
hi,
i would like to know you opinions .... (or what can possibly go wrong)
i just replace AGM battery with VanVolt 185aH LiPOFE4 (charging currents are rated for up to 200A , thats perfect because GC alternator can push high current as high as 200A). After switching the battery coding was performerd by specialist (coded leisure battery as Lipo + 185A capacity). Battery is not charging while normal drive, it is charging only when i push 'the battery button' on dashboard (charing currents are around 120A). So far so good, i am able to use GC for 4 days off grid. However , last weekend i noticed that the battery is charging also during normal driving (around 80A). Does anybody knows why the charging relay works this unpredictable way ? Do you think it is OK to use it like this ? Battery have BMS system which block overvoltage.
Thank you for your opinion
