Steve Fuller
There seems to be a lot of discussion about this subject so heres my problem, my 2.5 tdi goes into limp mode when under load, the turbo seems to working OK but it sounds like boost is leaking out somewhere, I have checked/redone all the hoses etc. I do not think it is overboosting but maybe the air leak is allowing the airflow sensor to be fooled into allowing too much fuel as I do get black smoke under acceleration plus the sound of the air leaking out, strangely it also makes a sound like an organ note at certain revs. There is an oily patch at the bottom of the intercooler so I suspect it could have a leak but you cannot detect anything with the van stationary only when it is pulling. Any thoughts or experience would be helpful as I do not want to spend money in the wrong place. Thanks in advance. Steve
