jimmywease
I'm rather unimpressed that my 2017 T6 Beach recently went into limp mode, with dpf light on and glow-plug warning lamp flashing. I took it into the dealership and their investigation has revealed 'fault P2463' which apparently means 'dpf restriciton'. The vehicle is showing 42.9g of soot in the dpf, although they weren't sure what weight of soot is unacceptably high until further into their investigation...
The upshot is a minimum charge of £166+vat for investigation and a forced dpf regeneration, with the delightful possibility of further (much higher) charges if unsuccessful.
I'm in two minds really:
On the one hand, the vehicle had plenty of short-journeys during it's first year: 200 miles as a dealer demonstrator, then part-time use for school runs etc (although I usually used the Golf) with occasional long runs. It's second year was better: 35mile motorway commutes and longer runs, camping in Wales & France. I've probably driven too sedately for much of the time, conscious of fuel consumption and child-safety. I've also probably allowed the fuel tank to get too low a few times, instead of keeping it 1/4 full. The DPF light has come on a couple of times before, so I've followed the advice and cleared it. I suppose £200 for unclogging it isn't too bad, given that it only needs a service every 20,000 miles.
On the other hand, it's frustrating that I've spent a small fortune on a vehicle AND paid for the extended warranty, only for it to limp into the garage for five days (it happened on a Friday morning). Also what if the dpf needs replacing and that £200 becomes £2,000? Is this really acceptable or should I be contacting VWCS?
Sorry if I'm going over old territory, but I couldn't see much on the non-warranty aspect of dpf issues.
