Fridge Electrics - Relay
P
paddymounter
tr7 3js
T5 SE 174
My fridge is u/s!
I have checked the relay operation with it out of the van and it works!
What I would like to know is should the relay 'Click' when I attempt to switch it on from the overhead even if the control unit is faulty?
Regards
Paddy
New owner!
My fridge is u/s!
Regards
Paddy
New owner!
If the control unit believes there is a fault with the fridge it won’t engage the relay.
The control panel considers three type of fridge faults.
1. The fridge thermostat is faulty (out of range) or not connected / shorted.
2. The fridge controller is sending a error signal ( Pin D) on Fridge ECU to the Control Panel and thus the Panel will store error and stop the fridge
3. The control panel doesn’t see the correct electrical load on the output pin, ie it doesn’t see the fridge relay in the circuit.
I would suggest faulty control panel is least likely.
Happy to help with more detailed diagnosis when I am back home tomorrow.
But if you can take a photograph of the Hardware Menu in the diagnostics menu with the fault active then I can help, also if one of the lower right value is cycling between values, then take a photo of the two values.
Clear the faults and then try the fridge again then take a photo of the fault codes in the diagnostic menu as well.
Hello A
I have used the shorting link on the thermostat pins on the controller without any result!
I need to work out how to get the diagnostic menu up on the control panel!
Paddy
Hello A
Paddy
@WelshGas has posted the way into the diagnostic menu lots, if you do a quick search.
But if you have shorted out the thermostat pins on the fridge controller - in reality that is all the control panel is doing (all be it via the relay and based on the fridge temp) - so more likely the fridge controller, fridge compressor or power feeds to the fridge is the root cause. The fridge does have a voltage threshold that it won’t work below.
Hello A
Paddy
1. Hold down the centre of the rotary button together with the menu button (button below with the squares on it)
2. You will get the hidden menu.
3. Rotate the rotary button to get to "VW diagnose" and select this by pressing on the centre of the rotary button.
4. If no errors are present it will display "no errors"
5. If Errors are present then a list of errors will appear
6. Press the centre of the rotary button again to delete all the errors
7. Repeat process above just to check that errors have dissapeared!
8. Re-configure the time and date if neccesary.
Any problems should be resolved assuming these are Electronic and not Mechanical.
Error Codes from Control Panel.
1 = 1 = Pop-up roof
2 = 2 = Plumbing Heating
3 = 3 = Cool box Cooler
4 = 4 = Sewage wastewater
5 = 5 = Fresh water
6 = 6 = Outside temperature
7 = 7 = Battery
Error Code Defect Fault
1010 1010 Short-circuit to (earth) roof
1001 1001 Fuse / short circuit to (plus+) roof
1100 1100 Short-circuit output Roof "on"
1101 1101 Fuse roof "to"
1110 1110 Short-circuit output Roof "to"
1111 1111 Fuse starting Roof "to"
2100 2100 Short-circuit output heating on / off
2101 2101 Fuse output heating on / off
2001 2001 Interrupt input heating 30
3100 3100 Short-circuit output coolbox
3101 3101 Fuse interrupt output coolbox
3001 3001-J698-cooler input error "Active"
3010 3010 Short-circuit input icebox "actual temperature"
3011 3011 Interrupt or fuse input icebox "actual temperature"
4000 4000 Short-circuit to ground water level sensor
4001 4001 Fuse circuit to plus water level sensor failure
5000 5000 Short-circuit to ground water level sensor
5001 5001 Short circuit to plus water level sensor failure
6000 6000 Short-circuit to ground temperature sensor or for outdoor temperature
6001 6001 Fuse / short circuit to plus two temperature sensors for outside temperature
7001 7001 interrupt input interrupt input D +
I also connected a battery direct to the controller and nothing happened!
Paddy
Paddy
Probably fridge controller - speak to Penguin refrigeration for further advice and replacement part if they recommend it.
I have error codes 3101, 3001, 3010 and 3011 is it still looking like the controller?
Paddy
Paddy
Is that with all the wires back to normal and with you having cleared the codes and then read them ?
Do I need to refit the controller? I did connect it directly to a battery with no response :(
If you have removed the fridge controller than don’t worry about all the fault codes, it will log all the faults possible with it disconnected
It's actually cancelled them all and the relay is clicking!
Paddy
I removed the controller! Do you think the controller could be ok?
Paddy
Paddy
If the control panel doesn’t have any faults and the relay is clicking. Then my guess is that the Fridge controller was flagging an error when switched on. So I still think it is the Fridge Controller.
Thank You A
Paddy
