F
Findlay94
Please could someone share some advice how to get my fridge running again. I've tried lots of things/fault diagnosis:
Problem:
Fridge wont start - the relay clicks, but the compressor doesnt start
A few times, fault code 3001 (J698 Cooler Input Active) has come up, clearing it made no difference
Battery is fully charged, attempts using hook-up, engine power or both haven't helped.
I've measured the voltage across both batteries, I think it was 12.6V, so appear heatlhy
The heater fires up on battery, hook-up. 230v plugs work
I've set the temperature to -18, relay clicks and light comes on. If it is set to say 10c, when it was about 8c ambient today, no relay click and no light (as expected)
I've fitted an LED as per PenguinFrigo's diagnostic instrcutions, but it didn't light up. LED tested seperately as okay
Next, I measured the voltage on the relay next to the controller - 13V between connections on the relay
The voltage on the leads fitted to the controller measures only 1.2V - which says it's not receiving enough power!
The wires seem to go under the cabinet - Is that to the earth shunt?
If the relay is seeing power, and clicking, Im not sure why the controller doesn't seem to see enough voltage.
Am i missing something?
Any ideas or advice would be much appreciated!
Problem:
