ADevon
- Messages
- 26
- Vehicle
- T5 SE 140
Worked fine for the past 5 years .... only just started playing up - something strange happening.
Hi there
Did you get anywhere with this? We seem to have a very similar problem. Fridge works fine on 5,6 & max. On settings 1-4 there is either no response (compressor starting) from the controller or the compressor starts but turns off after a short while, not to come back on regardless of fridge temperature. Leisure battery showing 12.6 volts.
Adrian
Ah, thanks @sbmcd. This seems like an often-enough problem that VW should stand behind it in- or out-of warranty. Anyone have any idea how much a new fridge costs (including labour)?
I was thinking about 1-3C was reasonable as you would with a domestic fridge. It was the apparent change in the temperature when I moved the milk bottle away from the back wall of the fridge, nearside of the Cali, that surprised me.
https://vwcaliforniaclub.com/threads/changing-the-leisure-batteries.20839/Hi had the same problem not used the van for a while had a solar panel connected and panel read 100% but the fridge kept clicking off so after checking the VW club site for info on the problem, plugged into a shore supply and left the Van on charge for half an hour, went back fridge started ok and is now running fine. VW club THANKS! for the info, my Cali is 11 years old problem sorted domestic batteries duff, I have 2 off them.
Anyone any idea the cost of the batteries? or can recommend a non VW battery.
Has any body got any electrical diagrams of how these fridges work electronically? My mechanic and me are finding the converter electrical box difficult to work out. Si from hoveJust an update with some very good news.
Penguin recommended a local Fridge specialist in Ipswich, just returned after having a thorough check carried out, fridge is working fine, the leisure battery was causing the fault it's on the blink, so delighted that all I now have to do is replace the leisure battery.
Can anyone recommend the best type of leisure battery, and where best to go to get one, I am anticipating it will be a specific size if it's under the drivers seat and possibly unique to VW?
Any advice would be much appreciated,
Thanks to all
