Fridge question
Jay gas
Southampton
There’s probably a simple answer to this but I had a question regarding the fridge in the ocean.
While hooked up on mains on the drive last night myself and the little one spent the night camping out. I noticed that the fridge was running while hooked up to the mains even though the control panel had the fridge turned off. Has anyone else had this happen or am I just being a doofus and have missed something simple with regards to the fridge ???
In the Ocean, the fridge shouldn’t be operational unless switched on at the control panel...
Try resetting the control panel.
It does seem odd. Does it still run if hook up is disconnected?
No it doesn’t seem to run when not hooked up. It has been back to breeze for an issue with the strip light which turned out to be a wiring fault. That has been fixed but not sure if the fridge issue could be linked to any of the work that was done to fix that fault. Ah well looks like she’s going back to breeze for them to have a nosey
Hi we have just purchased a new T6 and the same thing is happening with us
Fridge turned off on the control panel but its running
Can I ask how do you do a control panel reset please
Also been camping out on the drive.....not actually had the pleasure of a night away yet
Thanks in advance
Thanks in advance
For those of you who don't know, if you ever get any problems with roof stuck or any other error say with the heater or fridge, you are able to access the hidden menu in your control panel as used by the VW Engineers.
Access as follows:
1. Hold down the centre of the rotary button together with the menu button (button below with the squares on it)
2. You will get the hidden menu.
3. Rotate the rotary button to get to "VW diagnose" and select this by pressing on the centre of the rotary button.
4. If no errors are present it will display "no errors"
5. If Errors are present then a list of errors will appear
6. Press the centre of the rotary button again to delete all the errors
7. Repeat process above just to check that errors have dissapeared!
8. Re-configure the time and date if neccesary.
Any problems should be resolved assuming these are Electronic and not Mechanical.
Error Codes from Control Panel.
1 = 1 = Pop-up roof
2 = 2 = Plumbing Heating
3 = 3 = Cool box Cooler
4 = 4 = Sewage wastewater
5 = 5 = Fresh water
6 = 6 = Outside temperature
7 = 7 = Battery
Error Code Defect Fault
1010 1010 Short-circuit to (earth) roof
1001 1001 Fuse / short circuit to (plus+) roof
1100 1100 Short-circuit output Roof "on"
1101 1101 Fuse roof "to"
1110 1110 Short-circuit output Roof "to"
1111 1111 Fuse starting Roof "to"
2100 2100 Short-circuit output heating on / off
2101 2101 Fuse output heating on / off
2001 2001 Interrupt input heating 30
3100 3100 Short-circuit output coolbox
3101 3101 Fuse interrupt output coolbox
3001 3001-J698-cooler input error "Active"
3010 3010 Short-circuit input icebox "actual temperature"
3011 3011 Interrupt or fuse input icebox "actual temperature"
4000 4000 Short-circuit to ground water level sensor
4001 4001 Fuse circuit to plus water level sensor failure
5000 5000 Short-circuit to ground water level sensor
5001 5001 Short circuit to plus water level sensor failure
6000 6000 Short-circuit to ground temperature sensor or for outdoor temperature
6001 6001 Fuse / short circuit to plus two temperature sensors for outside temperature
7001 7001 interrupt input interrupt input D +
Access as follows:
1 = 1 = Pop-up roof
5 = 5 = Fresh water
7 = 7 = Battery
Thanks welsh gas I’ll have a look at that tomorrow morning
Access as follows:
1 = 1 = Pop-up roof
5 = 5 = Fresh water
7 = 7 = Battery
Thank you
KGCali
KGCali
Bertie17
T
Toshette
T
Ambler
Ambler
Ambler
