Fuel problem
jts46
jts46
Derbyshire & Lot et Garonne
T5 SE 130
When ignition switched (engine not started) what causes the "squelch " , "whoosh" noise?
2.5, 5 pot engine, 2006.
Fuel pump priming?
Great engine. Loved mine - fuel pump I think as suggested.
Doesn't a Common Rail Diesel have two, a low pressure one in the fuel tank and a high pressure one after the filter for the common rail?
I think this mill is a PD isn’t it? If it is then no hi pressure pump.
If it’s a PD engine then I think the fuel pump is part of the vacuum pump on the end of the cam on the cylinder head?
