Sian
Hi,
Since you were all so helpful fixing my battery issue I am throwing to you my next problems!
I assume it is the waste water tank under the kitchen sink and the white screw circle opens into it? I think my screw cover needs replacing as it doesn't screw tight but inside the tank is disgusting! How does everyone thoroughly clean theres? Also do I need to go to VW to get replacement parts, as at the moment if that tank was full I assume it would leak out of the hole?
When the sink empties (very very slowly) - there is a loud dripping noise which sounds like a leak - the (rubbish) habitation service people said it was fine. Is it normal to hear loud dripping as it empties into the tank?
Also (please see picture) I have found some moisture around near the what I presume is the water pipe. Again i have been told "everything is fine". Would you expect this level of moisture without a leak?
Last but not least my wardrobe door has broken in half with half stuck around the other side - can this be replaced - if so is this another vw job?
Thanks in advance.
Thanks in advance.
