Dylan
Member
Mine is a 2014 so could be different. I used a 7.5amp fuse in the upper section that was an Ignition live for the AirCon Blower Fans.View attachment 39359 Hello,
I wish to hardwire a dash cam and I’ve attached a photo of the dashboard fuse layout in my 2012 T5 SE. I want to piggyback onto a switched live fuse. Can anyone please advise me on an appropriate fuse?
Martin
Thank you WelshGas. This is very helpful.
Thank you Allan.Your panel looks the same as mine but knowing VW that may not be the case.
I have done the same and was told the following fuses on a 2010 are ignition live by a reliable source....I can't say who though
On the bottom section:
Sc28
Sc22
Sc10 or if you need it to be at the top section use sb22.
These will all active when ignition switches on and turn off when ignition is off.
The fuse holders are numbered from left to right in the centre between the slots. Difficult to see in poor light though. One is a mini fuse so not a lot of use.
I used S28 on the bottom section. Don't know what it feeds as I didn't turn on the ignition while the fuse was out. I tested the feed before I connected it to the dash cam though, and it did switch with the ignition.
Hope that helps
Alan
