Shaun Clark
Does anyone have a fridge that works as described in the user manual ie the temperature setting does anything other than freezes the contents unless you constantly have it set to night mode??
Without wishing to tempt fate, mine seems to behave. Have you checked the plastic tray under the freezer (top of fridge), make sure that is pushed all the way back. If this is pulled a little forward it can cause freezing issues.Does anyone have a fridge that works as described in the user manual ie the temperature setting does anything other than freezes the contents unless you constantly have it set to night mode??
Oh that sounds a nightmare.Thanks for the feedback Mr T and I will check the tray. We are now on our 3rd new fridge and it's still misbehaving so you'd kind of hope the dealer would have tested it. That said you might be right on the tray based on my experience with VW technical. I'll let you know.
Our fridge was at the beginning behaving oddly. It didnt really matter what settings it was; it was constanly running full throttle, everything froze. At lowest the coldbox was -26c and main compartment -5c. Fridge killed the leisure battery - it lasted only 10-12hours on final stage. Then the battery and lastly fridge was replaced under warranty. Now it works.Does anyone have a fridge that works as described in the user manual ie the temperature setting does anything other than freezes the contents unless you constantly have it set to night mode??
Hello,Does anyone have a fridge that works as described in the user manual ie the temperature setting does anything other than freezes the contents unless you constantly have it set to night mode??
Our fridge was running on full power no matter what setting was used. It was replaced on new unit. And now it seems that its also broken.Does anyone have a fridge that works as described in the user manual ie the temperature setting does anything other than freezes the contents unless you constantly have it set to night mode??
HelloWe have the same type of thermometer setup but unfortunately even when full and set to one light it still freezes the contents hence the reason we keep setting it to night mode. I just wanted to know if they were all the same ie a design fault or if we have just been the lucky ones. We did have to purchase a 12V cool box as a backup and the dealer did cover the cost so they are as confused as we are!
Is that supposed to be something not to be done ?Hello,
I bought (and payed) a GC 600 the September 1st, had to wait till November 17 because of a huge amount of problems, see this forum, I had them all.
And, …tomorrow back to the garage because of a yellow light(motor failed).
But I have an answer for your fridge.
I had minus 2 degrees. There is a technical follow up from the Belgian importer.
Under the freezer you’ll find a plastic plate which is used to receive melted ice. This must be pushed firmly to the bottom of the fridge. I went from -2 degrees to +4. I know it's borderline, but it's already better.
Good luck
