Help choosing drive away awning, please
Themadwife
Themadwife
Southsea, Hants, UK
T6.1 Coast 150
Downsizing from 7m motorhome.
Have T6.1 Coast, 2 medium sized dogs.
Attend dog agility shows/ training camps. Want drive away awning that I can erect alone.
prefer fitted groundsheet so dogs don’t escape.
Doesnt have to be large. Want it to give more space, keep Trans k9 dog crates in. Let us sit at our table and chairs.
Do they attach to awning or the casing of the awning?
what are the pros and cons of different ones?
Dont want to make an expensive mistake….any suggestions to help, please
I’ll be interested in the responses you get. We’ve had our Ocean nearly 4 years and when buying an awning had some of your issues though we only have 1 dog ( black lab ).
We wanted more space, wet dog, wet clothes and just fit in table and chairs too
We didn’t get a sewn in groundsheet as some sites say ‘no groundsheet’ but I can understand the ‘keeps them in better’ thoughts. ( though none are so robust as to prevent dedicated escape artists !)
Putting up on your own, doable… maybe, but not easy . Our friends have the add on Front and Sides set up that I’ve seen and thought looks much easier to do but again that doesn’t accommodate your need for sewn in ground sheet.
We have the Vango Palm , air beams. It’s one of the smaller awnings but is size enough for our needs.
  1. We have a Vango Faros low, basically the same, but with fibreglass poles rather than air beams, so smaller and lighter when packed.
Hi, we have had one of the Kampa vw travel pod motion air. Easy to to put up. The ground sheet was clipped in and came about 6 inches up the sides. Was a good size and just attached it to the awning rail on our T5 at the time. If you are close to any leisure outdoor shops see if they are having a demo days. I know Lowdham’s do them.
We have the Outwell Newburg 160. We have the poled version as we have always been tenters and not keen on inflatable. 2 adults and 3 kids and a springer! We mainly use it to put the bedding in if we go out for the day but husband and I have sat in our chairs in it of an evening! Pack size is really small.
I've also been looking at driveaway awnings. I want the smallest possible pack size that gives the following simple features: covered entry to van and somewhere to offload stuff into when we're sleeping or have driven away. I'll mull things over for a while yet, but I thought it might be useful to share some info I have nerdily gathered on pack sizes...
The following is my list of currently available awnings from Vango, Kampa, Outwell and Outdoor Revolution, and their pack dimensions in cm, along with calculated pack volume in cm3, sorted smallest to largest. It's not every awning on the market, as I didn't bother to record bigger beasts.. It might help in your deliberations on best awning for you...
MfrNameLWDvol
OutwellTouring Shelter (not fully enclosed)74x20x20
29600​
KampaTrip70x24x24
40320​
OutwellTouring Air Shelter (not fully enclosed)72x24x24
41472​
VangoFaros II75x27x27
54675​
KampaAction72x27x30
58320​
OutwellLakecrest62x31x31
59582​
OutwellMilestone Shade71x29x29
59711​
Outdoor RevolutionCayman Outhouse66x25x38
62700​
KampaSprint Air72x30x32
69120​
Outdoor RevolutionCayman Classic Mk272x32x31
71424​
VangoCove II75x31x31
72075​
Outdoor RevolutionCayman Cona (F/G)76x34x28
72352​
OutwellWaystone 24067x33x33
72963​
Outdoor RevolutionCayman (F/G)72x33x31
73656​
KampaTrip Air72x32x32
73728​
KampaAction Air68x34x36
83232​
OutwellWaystone 16073x34x34
84388​
OutwellMilestone Lux69x35x35
84525​
VangoKela V Air78x32x34
84864​
VangoFaros II Air75x34x34
86700​
VangoAgora Air VW65x37x37
88985​
VangoTolga Air75x35x35
91875​
KampaCross Air76x35x35
93100​
VangoCove II Air74x39x39
112554​
OutwellNewburg 160 Air80x38x38
115520​
VangoMagra Air75x40x40
120000​
VangoKela TC Air78x38x41
121524​
Outdoor RevolutionCayman Cuba Air80x40x38
121600​
Outdoor RevolutionCayman Cona Air80x40x38
121600​
OutwellParkville 200SA79x40x40
126400​
OutwellBremburg Air72x42x42
127008​
VangoLongleat 800 XL (tent!)80x43x43
147920​
The last one is our tent, from pre-van days, left it in for comparison.
MfrNameLWDvol
29600​
KampaTrip70x24x24
40320​
41472​
54675​
KampaAction72x27x30
58320​
59582​
59711​
62700​
69120​
71424​
72075​
72352​
72963​
73656​
73728​
83232​
84388​
84525​
84864​
86700​
88985​
91875​
93100​
112554​
115520​
120000​
121524​
121600​
121600​
126400​
127008​
147920​
Thanks! Great job!
To be honest, we should also include the Quechua Air Seconds Base XL
. I have this tent, it's very robust, extremely easy to put up, it has a removable groundsheet, you can use it either very closed attached to the van or at a distance with the wind out awning, like i had in this pics from 2 years ago:
I like how it’s attached to wind out awning……can you do this with other ones, or is it height dependant of the ‘tent’?
you basically have the "wall" of the tallest side that can be completely opened, 2m high, so ideal to use with a Van like ours. This "wall is also straight vertical, so you could also park right next to it. I can't comment on others tents as i have no experience unfortunately.
How does the Quechua fit to the Cali ? Also can you stillioben and close the door
it depends how you position it. The way I used it, when I have it attached to the Cali, I open the big side wall and attach it somehow on the awning case. I don't see the need why it has to be physically attached at all cost to the van. If i need to drive away, roll the side of the tent down, zip it closed and drive away.
