Albino
My control panel display shows that my Leisure Batteries % drops quickly – even after charging via hook-up overnight. I think this is a false reading as there still appears to be plenty of life in LBs, even when reading 0%. (I charged overnight on Thursday via hook-up cable and since then have had fridge running on max for several hours, laptops/tablets charging, lights on, powered aux heater on several times etc - LBs still appear to be going strong).
In addition, the panel shows a constant reading of >>20A – which I think indicates greater than 20A flowing in (Even though it’s not connected and the engine is not on).
It seems to suggest that the panel is getting a false reading regarding the 12v system. From reading through some of the tech docs, would I be right in thinking this is an issue with the Battery charge control measuring resistor N162?
I have also checked the cube fuse on the rear LB which appears fine and also completed a panel reset and 2nd battery off and on again in the diagnostic menu.
We’ve got a few wild camping trips planned and would like to have a clearer idea of the state of the batteries so would appreciate any ideas on how to resolve this. Thanks
FRIDAY PANEL PIC
SATURDAY PANEL PIC
MONDAY PANEL PIC
FRIDAY PANEL PIC
SATURDAY PANEL PIC
MONDAY PANEL PIC
