Jrhbright
I'm hoping to buy a used T5.1 California SE and I'm hoping to get some definitive help about the options for the heaters. From reading a lot of posts I think I've got it sorted in my head:
-The parking heater used diesel to create hot blown air, programmable via the central control panel and it's used to heat the whole van while you are camping. I'm pretty sure this is standard on a Cali?
-The auxiliary heater is something which uses diesel to heat up the engine coolant....Is this standard equipment on a Cali? How does this function? Does it only run to speed up heat-up time once the ignition is started or does it run before you start the ignition? Is it on a timer? If so does it also turn on the cab fans to heat up the windscreen? I've read somewhere about a remote for the auxiliary heater...is this an extra option?
Or have I missed something completely!
Thanks for helping, hopefully this post will go on to help other newbies who are confused about all the different heaters.
Sent from my Pixel 2 using Tapatalk
