yuchili
When using 230v elec hookup, how many Amp can the onboard charing unit provide to charge the 12v leisure battery?
I always thought that fuse was to protect the leisure battery in the event the split charge relay failed and the starter motor tried to use the leisure battery to start the engine?The charger output is fused at 30A so must be in the 20s
That particular fuse is 80A.. its all on the circuit diagrams..I always thought that fuse was to protect the leisure battery in the event the split charge relay failed and the starter motor tried to use the leisure battery to start the engine?
