alstevens
Had the not uncommon abs warning light staying on problem … 2015 SE 180 manual - 18000 miles - took it in today for a diagnostic... Faulty sensor ? well that doesn't sound too bad, how much to replace ? That'll be 435 sterling to you sir …. ?????
Story is that fitting a new sensor (78) requires also a new wheel bearing and much mechanic time....
So what to do ? replace a perfectly good and little used wheel bearing and stump up or ignore the irritating yellow bits on the dash... what do you think folks ???
al
al
