s2bear
Hi, I drive to Sainte Foy Tarentaise (just opposite Les Arcs) 3 -4 times a year.
The Sanef Tolls are around €95 each way.
well worth getting one of these tags for the windscreen if you don't have one:
https://www.emovis-tag.co.uk/
I usually get close to 30mpg and it's about 620-650 miles from Calais so about 93litres of fuel. Autoroute prices a few weeks back were €1.80-2.02 per Litre. Ouch.
A26 Calais-Reims, then Dijon, Lyon, Chambery, Abertville, Moutiers, Bourg St Maurice.
I always do the driving myself and in one day but we'll have a proper lunch stop and after I've eaten I'll have a nap whilst the family do something else.
I always use winter tyres but there are all season tyres now with the 3 peak mountain snowflake and I think they're pretty good.
If you do end up needing chains you probably won't need them until the last few kilometres, if that - they're usually pretty good at ploughing the roads but, 2000m is pretty high so do definitely take chains - Gendarmes will make you put them on in the layby in Bourg St Maurice if conditions are bad .
if you're running standard size tyres (235/55R17 or 245/45R18) the manual says chains won't fit. That's referring to 'conventional' chains - because they wrap around the back of the tyre and could foul the suspension etc. There are 'no fit' type of chains/traction aids which attach to the wheel nuts and I've seen these fitted to standard size tyres. I run 20" tyres so have to use this kind anyway.
See here for some examples (other places sell them too):
https://www.roofbox.co.uk/scripts/rbvehsel3.php?emulate=snowchains&query=8505&Sub_Model=&TID=333
Be aware of the speed cameras as the limit drops to 90kmh in the Chambery area - it's really easy to miss and I've been done at 92kmh so there's not much tolerance. (it's not a huge fine and there's an app to pay with)
Everyone is different but I never bother with an overnight stop. The one time I did, it just took twice as long but I was the same degree of knackered.
I'm tied to school hols though so time is precious. If I wasn't then maybe I'd take an extra day and see some things on the way. If you're not in a hurry and want a bit of luxury - Hotel Le Cep in Beaune is a couple of minutes from the autoroute and a valet parking / medieval town affair with some nice restaurants dotted around. it's very scenic and en route.
if you're doing self catered and want shopping there's a massive Super U / L'Eclerc etc in and around Bourg St Maurice. There's also a great Ski/Board Shop there called Labo Shop in case you forget anything.
EDIT: if you're going on school holiday / changeover dates then the road into the Tarentaise can be a bit of a shocker AND, the Gendarmes block all of the autoroute exits to stop people taking shortcuts/ratruns. There's not much you can do about it other than try to get there as early as possible. We often get the the 06:50 Chunnel but the earlier the better. sometimes we go through the night but I'm always way too excited to sleep before hand so end up having to stop for nap after nap on the way.
