Perfect!leave small chocks in place on the ground for position and drive back up to them, also as Amarillo said peg out some string as a marker from the front to the back wheels......
What is your objection to markers on the grass or pitch?
I peg out a 2.5m cable parallel with the wheels and reverse alongside. Perfect alignment every time.
Great idea, I like it! You could maybe also attach some sort of plaque to it (number plate size?) with a ‘pitch in use/no parking’ message.
The daisy marks the centre of the wheel. All I need do is look out of the window and reverse parallel to and alongside the line, stopping when the daisy is aligned with the centre of the wheel.
When not a marker, the cable is used to lock the bikes together and to the bike rack.
Um. wouldn’t the awning mark the pitch as occupied ??Great idea, I like it! You could maybe also attach some sort of plaque to it (number plate size?) with a ‘pitch in use/no parking’ message.
You would hope so, but I have seen neighbours park too close before.Um. wouldn’t the awning mark the pitch as occupied ??
