Indents on awning
Jennie
Jennie
Hertfordshire UK
Motorhome
hi. My awning has several indents on it. The Canvas is stretched but not pieced. It has 3 rows of indentations running from nearest the van to the outside edge. Each row is slightly differently shaped. They are deepest nearest the van and less Indented towards the edge.
I assume there is some debris, probably small sticks, rolled up inside the canvas.? How can I get inside the canvas casing to remove them. It is a 2001 California with a factory fitted awning. Any ideas gratefully received. Thanks. Jennie.
roll it right out and give it a clean / wipe - the debris will by science roll out with the awning ?
As above, if you're lucky the bits will stick to the roller and end up underneath, otherwise you been a broom and a step-up.
Thanks. Tried that & no luck. It seems stuff must be inside the metal awning case? Is that possible?
Thanks very much. I assume I need to remove the awning from the van to get a good look along it’s whole length or is it possible to see inside well enough from a ladder or. ???? Thanks again jennie
you dont need to take it off - get your henry hoover in there
