Hi can anyone help me with the removal of the trim in the photograph i have removed the screw bolts but i cant see what else is holding it on and don't want to break it any advice would be greatly appriciated !
Yes i can confirm its glued on you need to slide a small screwdriver along and pull at the same time this then releases also i found another small bolt screw at the tailgate end you need to remove the rear trims to reveal it !
