Intermittent ABS, Traction and start stop lights.
CYCLOPATH
CYCLOPATH
Blackdown hills, Somerset
T5 SE 180
Hi all, just read the thread on here. Following a recent oil change service, My lights come on occasionally when I turn on. It if I turn of and turn on again, they do not come on again? How do you explain this??
I have put on my Carista, L front ABS sensor. Looked at the sensor, looks ok, wires ok.
Looked on google. One Allan key and one connector to remove. £25 quid for new sensor .
But why is it intermittent
United Kingdom
T5 SE 180 4Motion
Poor connection in plug connector?
Alan Andrews
Alan Andrews
Staffordshire
There are known issues with circuit board for instrument cluster on some T5 vans.
It might be worth searching for these postings to see if symptoms are as you describe.
CYCLOPATH
CYCLOPATH
T5 SE 180
I did think of that, and so disconnected, and cleaned with electric cleaner. It made no difference. The odd thing is , if I turn on and the codes appear, then turn off ignition and turn on again, it goes. just turned on again, and no light
CYCLOPATH
CYCLOPATH
T5 SE 180
I googled a bit more and tested the sensor with my multimeter, it was an open circuit, ie broken.
I have removed it...I can see that it can be quite easy to snap it off.
The most expensive replacement I could find was £26. All those being charged hundreds of pounds for the job sounds scandalous, even an illegal rip off.
I removed the wheel, undid the wire clip, undid one Allan key and pulled it gently out.
dod4luce
dod4luce
Devon
T5 SE 180
Hope I’m not ripped off. Got same problem pretty much.
