Irritating rattle by rear heater control/vent/blind Any cure
MickyBlue
Sunny North Yorkshire
As per title, my rear passengers are on my case about it. :boohoo
If you tap the trim panel just below the vent outlet it's easy to induce. My suspicion is its the blind roller, or part thereof.
Is there a simple cure or is it a dealer job? I have tried with fingers to get the vent outlet out with fingers (to see if somethings loose behind) & I can nearly do it but need my trim tool which is at home, any advise welcomed.
TIA
Mike
