Is it a Dab Aerial
D
Dalboy
Hopefully an easy one to answer, but just out of curiosity what is the black rubber bit on some cali roofs (the front deflector part) I'm guessing a dab aerial although I thought when fitted these were in the wing mirrors
You could be right Martin but again I thought that also was in the wing mirror ?
Definitely NOT factory fit DAB aerial.
This is what I'm talking about little rubber block
That's covering the screw that holds on the front roof panel. A new design by vw for when it gets corrosion. Now its a 10 minute job to replace instead of 2 weeks.
Ohhhhhh cheers Vale, I was thinking it may be a way of improving my crappy radio signal (not Dab). all well thank you for clearing that up
LOL ;) (Am I too old to be writing LOL?)
It's the original GPS/Terephone Antenna... Sometimes called the roof combination antenna.
Part number: 7H0 035 507 (E)
Was an option on the earlier models, not sure about the more recent ones.
Never seen that , so if underneeth that rubber sits a screw that allows to remove the front roof spoiler your Cali is no longer safe by just locking the doors , just unscrew panel and your in....
Sounds not very well ....
reserves
Taff7996
6K
CampervanTime
CampervanTime
