Jack missing
CaliforniaBen
CaliforniaBen
Just noticed our jack is missing from our tool kit, what size do I need to get to replace it , with 2 ton be OK?
Probably not missing as may come with tyre inflators & a bottle of sealant. Two ton capacity Jack should suffice.
Do you have a spare wheel or just a tyre sealing kit?
If you have a wheel, you should have the jack, if you have the tyre sealing kit, you won't have one.
@TripleBee incorrect: Ours has a kit and jack (no spare originality). You get a jack because you need to lift and rotate the deflated wheel after you’ve injected the sealant during the inflation process.
@CaliforniaBen I think only the original type of jack will fit correctly into the moulded polystyrene tool holder.
Thanks for clearing that up.
N
TripleBee
TripleBee
Californication69
AlisonF
AlisonF
Dizzy
Viktorgeorge
Viktorgeorge
17K
jts46
jts46
