D
DamienP
First of all... thanks to members soulstyledevon and briwy for their own posts on here and inspiration.
Having used the beach a couple of times now I saw the benefits of having one big slide out tray and so decided that a DIY project to create something was the way forward. I investigated a few options and in the end I decided to go for the slightly more expensive over engineered approach with the well known slides from GSF rated to 250kg instead of some cheaper ones from germany at 130KG. I'll probably never have that much weight but i'll have something that is sturdy with peace of mind.
Making something full width for a beach boot is certainly more expensive than smaller ones for ocean as with the latter you can go for cheaper slides, smaller size aluminium and without the need to buy a full 2.4 x 1.2 sheet of ply.
Anyway, here is complete list and total cost of all materials including bits of trim etc
Container Red Slide Fully Locking 914mm £155.21
Multiflexboard Locking Rail Pack of 4 brackets £24.90
Flat Corner Plate x4 £4.00
Interlocking Foam Pads £4.95
Nuts and Bolts £7.27
12mm Ply Wood Sheet £30
Aluminium £61.00
Black bolt end caps £1.85
Black edge trim £8.00
TOTAL £286.83
So onto some pictures that I took...
Aluminium from a local shop... I went for 3 inch main frame to match size of the slides
I got lengths that needed trimming to my own size... wanted to be sure they were accurate so cut myself.
Laying out the main frame and getting it all square ready for riveting
Main frame all assembled that will bolt to the rails. I put careful considering into this as something I was mindful of was not having all the weight just on the rails. I wanted to disperse on both the rails and on the foot floor.
You can see here how i've constructed it so that it sits evenly on both the rails AND the boot floor.... the top of the rails is 6.5 - 7mm above the boot floor surface (depending on whether you measure from the small 0.5mm raised squares)
Some initial bolting and testing of the mechanism in the garage
Making the floor of the tray.... ensure bolts are inset and flush with surface
Bolting it in and and finishing off
Decided to finish off with some foam pads in the tray and some trim to cover the edge
Aluminium £61.00
TOTAL £286.83
