It also happens on my bog-standard Dell PC.Martin said:... it does however only happen on the iPad for some strange reason.
Martin said:Dibz is correct on this and we are aware of the problem, it does however only happen on the iPad for some strange reason.
The best way around this until we can find a fix is to use Tapatalk ( To be honest the forum works much better using Tapatalk when using a tablet anyway)
NickE said:It also happens on my bog-standard Dell PC.Martin said:... it does however only happen on the iPad for some strange reason.
shambly said:I think a viewport meta tag on the template would help matters, to tell iOS the scale to draw the page at; It gets surprised by the page getting bigger as the adverts load and has to rescale.
coordinated said:NickE said:It also happens on my bog-standard Dell PC.Martin said:... it does however only happen on the iPad for some strange reason.
Hi, Nick
Which browser are you using on your PC?....could you describe what you're seeing ...
NickE said:Firefox, latest version (currently 19.0.2) on XP. Symptons: page loads then 2 seconds later "jumps" down a line or two. Happens every time on this site, doesn't happen on any other site, problem started - phew...I've forgotten...I just got used to it!
PS. As an ex Assembler programmer, I'll let you worry about this!
