Khyman Classic Dome Problem
H
hedy1962
Currently touring in Spain with new Khyman Classic Dome and having problems shutting sliding door without white conversion strip getting in the way - Probably something really stupid we are doing but anyone else have the same problem or advice - Thank you as getting chilly at night with door not closed properly!!! :?
We connect ours to our awning. I wind the awning out a couple of inches to give a little bit of space. Are you using an awning?
We are using an awning(factory fitted) - We watched the Khyman You-Tube Video and they pull their awning all the way in. We have had high winds in Spain all week - will it not cause too much pressure on the awning??? :crazy
We sometimes have the same problem. I think it is just about getting it positioned right. We don't peg it down until we are happy with the position of the Dome. (that might be a bit herder if it is as windy as you say though!)
The guys are right ......just don't wind the awning in to far ..Trial and error with positioning the khyam to get the tension correct ...it's never going to be perfect :thumb
Shane&Michelle
Shane&Michelle
Shane&Michelle
Yorkdubshire
Y
Verity
Juliette ryan
Juliette ryan
L
clarinetbcn
clarinetbcn
