Kitchen cabinet door won't latch
rcsb
rcsb
Hastings
T5 SE 140
Has anyone else had a problem with the kitchen cabinet door, the one nearest the front, not staying closed? Mine slides open, usually when I pull away up hill, then on the next bend the cutlery draw slides open. This is annoying because where I live it is hilly and bendy!
It seems to me that the lower rail that it runs in has come loose, if I push it (the rail) back into place the door will latch, but soon after the rail comes loose again. Can anyone help?
Rick
You need to make sur the latch "clicks in " when you close the door .
If the rail is faulty maybe the latch does not come inline an not closes propperly.
Take it out clean things and see if anything if broken/faulty...maybe it helps.
Presumably if your vehicle is 2015 you should still have a warranty. Get the dealer to sort it.
