sidepod
- Messages
- 6,908
- Vehicle
- T4 PopTop
So pull all of the 25/30A fuses one by one till the light goes out!I find it hard to locate the fuses in the diagrams, as the fuse positions do not seem to be numbered or anything.
My gut feeling is pulling the fuse won’t extinguish the led. I think it’s powered via the purple/white striped wires from the battery monitor unit J934 which is hard wired to the leisure battery.
For simplicity would the removal of this terminal block connection from the inverter not resolve the matter by taking the inverter unit out of the system and see if the OP’s battery drain issue stops then over to dealer to resolve?
Link posted by @yossarian at #43
As I suspected.I’m in the van now and I just pulled all the 30 amps fuses. None of them extinguishes the green led in the socket
I like that idea but how to remove that yellow socket? I’m trying but don’t want to break anything
As I suspected.
If there is no fuse in the line then it’s supposed to be on and probably isn’t the cause of your drain.
PossiblyI like that idea but how to remove that yellow socket? I’m trying but don’t want to break anything
Ok so repeat the charging process and see if it behaves differently.Btw, I was able to remove the plug from the socket
But your green light is NOT on right?
The manual sayWhat does the manual say about the green light?
There is a “i” icon next to it.
Sorry I disagree.So it’s not that causing your drain.
Agreed. My bad.Sorry I disagree.
The green light on means the child lock is disabled.
The way to disable the child lock is to plug something into the socket.
The inverter thinks something is plugged in & is therefore turned on.
A normal unused socket does not have a green LED lit. Putting an adapter in will make it light up.
