Leaking sink
Brownbetty
Brownbetty
Sunderland
T5 SE 180
Just made a cuppa and went to get a spoon from cutlery draw and noticed water on the shelf, checked for any leakage from plug outlet and everything was fine, then noticed the bottom of sink had tiny hole in, wife reckons it might be cleaning it with bleach!! What can I fix it with or will I have to replace, it's a 09 plate
For a quick fix you could dollop some silicone over the hole from
underneath.
Have you got a picture, i´d like to see that.
You could try a good epoxy, West Systems do a marine quality one. Or a bitumen sealant and metal plate fixed on the underside would probably work.
Thanks ArunAlec, I'll be able to fix it up somehow. Cheers
