HI GUYS
HAS ANYONE FITTED LED LIGHTS TO THE HABITATION AREA OF YOUR CALIFORNIA DOES IT MAKE A BIG DIFFERENCE & WHERE DID YOU PURCHASE THEM FROM I HAVE A 2011 CALI SE
I have fitted LED strips in ours. About a fiver off eBay and just wired into the standard lights.
Most useful is the one on the rear trim above the hatchback so that it lights up the boot area.
Hi Bruce.
Yes 12v, no transfomer needed. This kind of thing. If you want to get really fancy they come with a small control unit to alter the brightness and colours as well.
https://www.ebay.co.uk/itm/WOW-Wate...004863&hash=item3aae083f66:g:MIEAAOSwY0lXSSgB
I just picked up the live terminals (when switched on) on the standard switch and fed the wires out to the strips under the trim.
The LEDs are sticky backed and can be cut to length.
As they come off the leisure battery I don't think it has anything to do with the Canbus system. Ours have been on for a few years without any problems.
Hope this helps.
Any reason you need to put the switch on the negative?
Possibly to avoid earth faults if the LED fails. An incandescent bulb fails open circuit so we don't care where the switch is but an LED could fail open circuit or with a short circuit.It was explained to me once but I’ve forgotten. Something to do with the behaviour of the LED.
more likely for lamp monitoring.Possibly to avoid earth faults if the LED fails. An incandescent bulb fails open circuit so we don't care where the switch is but an LED could fail open circuit or with a short circuit.
