brooodie
I've had various pieces of conflicting information from different sources and appreciate any help or input the wise heads here might have. Sorry for the long post. If you can't be bothered reading the whole thing I'm looking for anyone with a T6.1 to check what their leisure control panel reports for draw when everything is turned off compared to the photo attached please!
T6.1 Ocean Delivered Nov 2021. My leisure batteries died earlier this year (wouldn't hold a charge) and were replaced under warranty last week, so they lasted about 2 years. After they were replaced, the Van centre told me that they actually misdiagnosed the initial issue and are blaming it on a parasitic draw on the leisure batteries from my Autowatch Ghost II Immobiliser, but they replaced the batteries under warranty regardless (thankfully). This made sense to me as the immobiliser stopped working when the leisure batteries died.
The tech told me there was a 1amp draw on the leisure battery (very dubious of this) after replacing the leisure batteries. My suspicion is that this number came from the control panel and not a multimeter and this it was rounded up, but I can't be certain.
So I then took the van back to the autowatch installer and sat with him for a good few hours going over things. It turns out that, yes the autowatch was wired to the wrong plug in the dashboard. He previously made the incorrect assumption that everything in the fuse box ran from the starter battery, so he switched to a set of wires that were powered from the starter battery. We confirmed this by multimeter, by disconnecting the leisure batteries, starter batteries, and the immobiliser in various combinations. I'm pretty confident it's now running from the starter battery as intended. (I trust his work)
However despite this mistake he was pretty adamant that the draw from the immobiliser shouldn't have been enough to kill the leisure batteries. We measured it on the multimeter at drawing 0.2A (by disconnecting and reconnecting the immobiliser, both when it was connected to the leisure batteries and also to the starter battery). I tend to agree with him. This leads me to my issue.
I'm still concerned that something is drawing from the leisure batteries (a short?) or there is something else wrong. My control panel reports a -1A draw at all times (see screenshot). Is this normal (can anyone else confirm)? I wondered if this draw was the display _itself_ being powered up but I'm not so sure about that, it seems high. Even turning on all the lights in the cabin doesn't change this. When I put the fridge on it drops to -5A and says 14 hours of power (that seems worrying low, but i know that it uses much more power when initially cooling the box).
I'm worried now that if there _is_ another issue that the garage might start being difficult due to the third party work on the van. The installer said he'd completely remove the immobiliser if there are further issues and the van centre refused to look into them, but hoping it doesn't come to that. Everyone has been helpful so far so I've no complaints but I'm just trying to head off any potential issues in advance.
Unfortunately I don't really remember what the 'normal' figures were for this panel prior to these issues happening, so any input from those with a T6.1 (or other if relevant) on what they see on their panels would be appreciated.
Any other tests I can do other than just leaving the van sitting? I'm going away on holiday for a fortnight next week so it will be sitting unused for that period. If I max charge the leisure batteries before I go I'd expect them on my return to be pretty close to fully charged (assuming there is no constant draw happening) given they are brand new - is this a fair assumption?
Thanks in advance!
Thanks in advance!
