K
katyjw
Hi all, I have looked through older threads but nothing quite answering my questions.
I've taken on the care and upkeep of a 2006 California from my Mum in exchange for limitless roaming. I've been doing some reading but wonder if anyone can help me with a fewqueries.
1) I understand if you don't have solar you should charge the van once a month on hookup to preserve the leisure batteries. Is this EVEN if it's pretty much a daily driver? I understand driving it means it doesn't get fully topped up by the alternator but is that not sufficient for battery health? The reason I ask leads me to my next question....
2) I believe I need to replace the leisure batteries as it has not been done for at least 5 years or more (if at all, mum isn't sure), the fridge keeps switching off when not hooked up, I put two and two together after panicking the fridge had died and realised this wasn't happening when I was on hook up so I take it to be because the battery level was dropping too low. I've tried charging for 48hrs but battery still seems to drop to 60% in a couple of hours. So I'm guessing I need new leisure batteries?
3) I finally spotted the hatch for the leisure battery and it is a Varta 3DO 915 105 H - I googled this and it seems like this is a VW specific starter battery. I presume starter means for starting, as in a standard type car battery and not a leisure battery specifically (or am I being dim?) in which case is there a better leisure battery alternative before I invest in a pair? I saw the Varta LA80 mentioned a couple of times, is there a particular go to brand/model for California owners?
4) Last question, a while ago (again I didn't deal with it directly so details are vague) but there was an engine drain, battery was flat all the time, a camper conversion guy looked into it and found out the parking heater was causing the drain so he disconnected it, it did fix the drain but it frustrates me we have no additional heater, is this the earth shunt issue?
Can anyone recommend a good auto-electrician in Cornwall?!
Thanks in advance
Thanks in advance
