Why are you changing just 1 battery?I have to change the leisure battery on my 2017 ocean. I notice there is a cable going in to the battery. How do i remove it? What is the purpase of it?View attachment 118505
Did not know that! Now you doubled my expenses...Why are you changing just 1 battery?
The Ocean has 2 Leisure Batteries and both should be changed otherwise you will shorten the lifespan of the new battery.
Thanks , verry helpfull.I've done a writeup on how I changed mine here:-
https://k3yak.com/vw-california-leisure-battery-replacement/
Why are you changing the battery?Did not know that! Now you doubled my expenses...
They should last much longer that that. I still have the originals in my 2012 van but they are showing signs of age.I have to change the leisure battery on my 2017 ocean. I notice there is a cable going in to the battery. How do i remove it? What is the purpase of it?View attachment 118505
Glad your sorted, and now you know about the 2nd Leisure Battery.Just checked the battery under driverseat, had 12,6 V . Then i checked the fuses, nothing broken there... Then i looked into the control panel, it wass showing a flikkering G symbol, went into display settings , returnedd to normal display and the problem is solved! Now the displays says 100% and with the engine running charging 5 amps.
I don't know how but i'm happy!
Thanks to all helping thinking!
Is your profile up to date ? It says T6 on order..I have to change the leisure battery on my 2017 ocean. I notice there is a cable going in to the battery. How do i remove it? What is the purpase of it?View attachment 118505
Owner sinds 2017 , Now its T6 for sale...Is your profile up to date ? It says T6 on order..
My 2014 batteries also working well.They should last much longer that that. I still have the originals in my 2012 van but they are showing signs of age.
