Location of Control Unit J608 (CAN)
Coachella
Coachella
Torbay
Grand California 600
After finding a gem of a Energy Management document on the forum - I would like to know if anyone would know or has come across the Control Unit J608 (CAN) where its located in the camper.
Thanks.
Also known as the KFG Special Function unit. Under the dash in the passenger side (UK). Visible with a blue and a white connector inserted into it. It’s the blue plug often mentioned to be pulled if you are having certain issues.
OK - thanks for that @GordonH - i will take a look.
Does it have on the unit J608 - I am not sure if i am going to see the same since this is a Knaus MAN TGE - but after reading the energy management document - it solved a previous post of me asking about the step button - and also funny enough the battery boost button is on the same diagram. (first time seeing it). Also a lot of parts are VW labelled on the camper.
So i am guessing that since this was manufactured on the same production line as the VW Grand Cali - only thing that is different before going to the conversion company - is the Van part is MAN not VW labelled. There are some differences of switches(and location) , lights, etc done at Knaus - but i am betting that the base parts are the same VW parts. I will investigate and report back. (for those that are interested in the similarities / differences). :)
Part number is likely this?
