hiHi @Tompoole,
+1 for CityGate Wooburn Green,
they are a large Company who are a franchised VW main dealer for both Commercial Vans and Cars. (Restricted by VW in how they can operate. I.e. strictly to VW guidelines and procedures And costs imposed).
they (CityGate) have fixed every issue I have presented them with since the van was new, now 4 years old. (I have had more than my fair share of warranty issues, which have NOT been dealer attributable). They have carried out my routine maintenance to VW guidelines, so as to maintain the Factory Extended warranty on my Van.
Mine is a love hate relationship with them (CityGate) more to do with issues I have experienced with the Van since new (VW issues and the bureaucratic issues with VW, than the fault of the dealer, whom get the brunt of my frustration when problems have occurred).
City Gate have to been fairly good Compared to others dealer experience I hear about on this forum and the T6 forum.
Citygate have provided direct access to the Master tech and other techs if required and as requested, they have always provided a solution and sometimes gone above and beyond what would be normally expected when pushed.
I have recommended them to several on here before @GrumpyGranddad @andyinluton included, who appear to have had no issues with the service they have received From the dealer.
Servicing regime on these vans is a pretty basic affair, it is set by VW, it could / is carried out by many owners themselves, who are capable and who’s vans are generally out of warranty, similarly Indi’s are used by Many.
Fault Diagnostics are another issue.
No dealer repairs anything, it’s merely a case of :
Fault / issue = computer diagnostic of a fault = new part = payment. (Either you pay the dealer or VW under warranty)
Main dealers will be a higher Labour cost than an indi, parts cost should be similar. VW main Dealers will price match a like for like quote for servicing etc. (Within the parameters set by VW, I think Must be within 15 miles of the dealer and the garage who quote must be vat registered and using original VW parts)
the best advice I can give you is make a choice, give that choice a try, if you’re reasonably happy them all good, if not try another garage.
Breeze in Poole are highly recommended on this forum, the very little dealing I have had with them, I would agree.
I hope that helps a little and gives you what you’re looking for, (some comfort) but as always its a subjective matter and one you should make based on you’re experience. (One person’s experience may not be another’s and businesses don’t always cover themselves in Glory all the time).
cheers for info ill have a look
Your case probably goes to highlight the issue with Dealer and VW (bureaucratic)hi
thanks for reply,
I bought the cali from wooburn green Citygate, their customer service very very good , however I had two issues with van early on but both occasions they failed to fix issue and when battery died they simply weren't competent in their actions.... I would have loved to carry on dealing with them as customer service team very good but lost confidence in their problem solving ability.
I've been using a local garage who are superb but don't pick up and deliver , ill continue to use local-ish garage but really need the camper picked up and delivered as we both work a lot.
cheers T
Totally agree, I tested battery and told them it was shot but they said it wasn’t after doing a drop test without removing surface charge…. They suggested I should leave it in their car park for a week to see if the battery discharged itself , brilliant , very technical, there was no parasitic drain on battery and my battery tester said replace ….Your case probably goes to highlight the issue with Dealer and VW (bureaucratic)
if the dealer could get paid for simply fitting a new battery, they would have fitted one, but VW will not pay for the parts & Labour unless the dealer complies fully with its onerous systems.
which means a lot of the time the dealer looks inept, for lack of action.
VW make the dealer go through a prolonged process before they will authorise the dealer change a battery Etc. knowing only then VW will pay.
I know I had my starter battery changed after it failed, but only after the third or fourth visit to the dealer And call out by VW assist, who said the battery was shot!
Only then did they (the dealer) do the factory soak test which proved the battery was faulty From the start!
VW standard response seems to be, if it’s going to cost VW, fob the customer off with limited info and see if they return, if they do, try fobbing them off again etc. until the customer is so exasperated they either demand a fix or simply give up. Hence my “when pushed” comment above
your experience further goes to explain my comment:
”always its a subjective matter and one you should make based on you’re experience. (One person’s experience may not be another’s and businesses don’t always cover themselves in Glory all the time).”
I agree with you, a battery is either fit or unfit and is simple to test. (Not if you are VW apparently)Totally agree, I tested battery and told them it was shot but they said it wasn’t after doing a drop test without removing surface charge…. They suggested I should leave it in their car park for a week to see if the battery discharged itself , brilliant , very technical, there was no parasitic drain on battery and my battery tester said replace ….
That is incompetence my friend …..as said I’m more than happy with customer service ie they pick up deliver and always at end of phone but diagnosing battery fault is relatively simple job, and their approach rang alarm bells.
The other issue was a simple leak of rear tailgate… they had it 3 days then confirmed it leaked and needed to remove interior to locate leak…. It was only brake light seal leaking …. 10 min job.
Anyhow I’m rambling and sure they have many happy customers.
It’s a fantastic van love it to bits.
I may go back at some point soon to buy a 4 motion but doubt I’ll have it looked after there, but never say never I guesss
Didn’t know of them but made a note for when i’m out of warranty. Just up the road from meI use Revolution VW, an indy near Great Missenden. They aren't especially cheap but very experienced and I've never had poor service from them, on our Audi cars as well as the Cali. They aren't going to do pick-ups/drop offs or loan vehicles though, they're just a very small outfit.
