E
Well, if you open the tap to empty the tap and to get the water flowing fluently, the pump will start pumping, but without water, the pump will die soon.The manual told me to do it in order to empty the pipe to the tap without the pump kicking in once the water tank is empty. Thought it seemed a very complicated way of draining a pipe.
Exactly what I needed to know. Thanks very much. Can you tell I’m new at this!!??Well, if you open the tap to empty the tap and to get the water flowing fluently, the pump will start pumping, but without water, the pump will die soon.
The easiest way is to unplug the connector from the tap switch (not the sensor). In that case, the pump won't start, and won't run dry.
If you open the right cupboard, take out the drawer, you will find some connectors. One is from that switch. Just unplug, open the tap, the pump won't start, and the water will be sucked out of the tap into the water reservoir that is emptying.
That is the way I, and most here are doing it I suppose?
