Loss of power at 2000rpm in my T6 Ocean
D
David Willis
Sussex
T6 Ocean 204
Whilst driving my T6 Cali I have recently noticed that when I accelerate from approx 2000rpm, in the higher gears, there is a slight delayed response from the engine and a slight juddering as if there is a fuel supply issue..
Has anyone had a similar problem or any ideas as to what the problem might be?
Thankfully it is on a service plan and under warranty!
My beach did a similar thing. It was hard to tell but I could feel a loss of power . Not on pulling away but on going up the gears. They changed the dpf sensor in the exhaust and it cured it.i believe there was a recall too. Affects the engine management system
Thanks for that FB.. Yes it is happening only around 2000rpm, so when changing up etc.. I’ll contact the dealer re the recall..
