Manfridas
But diagnostic does not show the faultLike sidepod said in post #6
Have you replaced the mass air flow sensor.
And no black smoke when accelerating hard and overall van drives smooth as I still had it remapped now and after remap I got 128kw and 390Nm,so its very close to the stock now as it should be.But diagnostic does not show the fault
How do you know the engine was putting out 128kw when new?I decegree on your thoughts that over the years and especialy this kind of milage engine looses that much of power is normal,my last van was a T4 2.5tdi with red i (111kw) and I went for the remap,so tried her on the roling road before and after and figures showed 110kw before and 120kw after,Nm was increesed more but I cant remember excact no. And the milage was even higher on that van. And before that I had another T4 with the same engine but it was with the blue i (65kw) engine,also done remape,and before and after roling road that was also very close to what the stock should be,after remap went up to 85kw. Most of my cars I owned I had them remaped and I got to say never had such a high difference in what should be.
My van is 2004 so it is pre DPF model. But any way answering to your question is my van 128kw now but it should be more? Yes that’s correct because it has been remaped now and as you remap stock 128k then it should be at least 140kw. Injectors checked,turbo replaced new,EGR replaced new,exhaust catolic converter new,no faults on the diagnostic,intercooler doesn’t look like its leaking,didn’t take apart to have a closer look,perhaps I shouldSo if you´re 100% sure that its not the intercooler and you´ve
just had a new turbo fitted and the DPF is also a new one then
it must be some sensor or something with the ECU ? or not.
Have you got 128kw right now but you should have more ?
I´m a bit confused as to when you had it remapped.
He already is spending.If you are that concerned then you’ll have to get your wallet out and start spending.
Well I don’t but this is newer model than T4’s I previously owned and I presume it should be some very close figures. If older vans was why this is exception. Its just my thoughts. If I new that this is normal I wouldn’t worry to much but all the mechanics are saying it shouldn’t be that much differentHow do you know the engine was putting out 128kw when new?
Since then compression rings wear, valves get carbonised etc?
Turbo was faulty anyway was needed to do something about itHe already is spending.
He´s just put a new turbo on it.
Someone said before that it wasn´t until they closely inspectedintercooler doesn’t look like its leaking,didn’t take apart to have a closer look,perhaps I should
the intercooler that they saw a hairline crack in it.
If thats the case, whip it off and fit a Forge one
If not, you need the advice from the Guru.
