Jeff_Brown
Hi All
Got back from being overseas and had the dreaded "Low Battery: Charge Now" warning on the console (never seen that before). It had been sitting for approx 3-4 weeks. This is on a 2019 6.1 California with original batteries (2 x 75AH).
Charged overnight for at least 12-14hrs on hookup and still have the same warning.
Tried removing the monitoring cables on the negative terminals of both batteries front and rear and reattaching to see if that reset them. No joy.
Have now removed the batteries (using the guide posted here doing cable in the right order etc and bagging them).
Metering the batteries I get 12.9v on the front and 12.5 on the rear (see attached pics).
Metered continuity on the cube fuse and it seems OK.
I've already ordered 2 x Varta LA80s which come tomorrow as well as couple of replacement cube fuses. I'm due to go away tomorrow so hoping to get it sorted (nothing like a deadline for pressure!.
I have noticed far less run time on the batteries the last year or two (had the van 4 years having got it 1yr old 4000 miles) and the batteries have probably not been kept in good shape (I didn't plug in during the winters etc and sometimes it would sit for a few of weeks at a time).
My concern now is that it may not be the batteries as they are reading OK and actually it's something else (fuse or relay somewhere?).
I will go ahead and put the new ones in tomorrow but if anyone can tell from what I've written here that's it's something else please let me know.
Any help appreciated!
Jeff
Jeff
