Paul1
- Messages
- 181
- Vehicle
- T6.1 Ocean 150
T6.1 window washer just dribbling. Under warranty in dealership expecting easy fix. No such luck, eventually after checking the obvious with no success the problem was discovered. Engine battery removed showing wiring been nibbled . Volkswagen state that if more than 20mm is damaged then a complete new wiring loom is to be fitted. Fortunately, dealership can replace part wiring but need to order the parts. Obviously not covered under warranty, cost inc labour and parts £ 380. Cali parked in cart lodge along side BMW which has never been chewed. Can it be true VOLKSWAGEN are using some environmental tasty material covering electric cables. Never had this problem with our other two cars over years parked in same place. Going to try mothballs and peppermint oil spray. Already got pair of sonic repellents, do they work ?
