Mirror glass
Mowbotman
Mowbotman
Hawes
T7 California Ocean 4 Motion
Replacing the os mirror £78 ?? And there are 4 connections so on the smaller two is there wires in the mirror for these ! I assume the larger two press on some other contacts when pushed in
See pic
No the big ones are springs and just clip it on the gimble. There’s a wire inside the mirror for the little terminals.
Much cheaper on eBay tho - about £15 for heated glass.
So hopefully should find some wires lurking inside
Yes 2 miniature spade connectors on the ends of separate black wires coming from inside the mirror through a hole on the van side of the mirror carcass. It doesn’t matter which way around they go.
they are the heater element connections. you will see them when you pop out the old glass
California Dreamin
California Dreamin
California Dreamin
