I can see the towing eye just below the towbar. It seems to be complete.There should be a towing eye as well & unless its in the glovebox the locking wheel nut key.
It has 17" wheels so not sure about Gunk and Pump.Do you get a Jack if you have the 18" wheels and a can of Gunk + electric pump?
Thanks for that. Dealer said it was just the jack missing but thought I would check.I don't have a towbar, so mine isn't the correct point of reference, but have found a few pictures online of kits with a towbar and that section that you mention is still empty. No convinced it is used.
Even looked through Will's @CaliforniaTime bike rack video on YT and he shows him taking the towbar from the kit at 1:32 and his looks the same too.
I don't recall ever having anything in that space.
The two keys for the removable tow bar are there, the two red Dots, one in a poly bag attached to the Tow ball, the other in the PolystyreneI am not sure what is missing but I not that you have a locking tow bar. Make sure you record the key number so that you can get replacements direct from Westfalia.
