Nav issue help
Defender90
Defender90
North Yorkshire
T6.1 Ocean 199 4Motion
Can anyone help I cant get the sat nav to follow the route and it doesn’t orientate in the direction of travel ,it works on the speedo central display
Hello, did you get this fixed as it sounds like the same problem that I now have?
On the T6, the likely issue is the NAv aerial has failed , cheap to fix by replacing the aerial if it’s within your skill set
if not try Sat Nav systems chertsey (contact Hamid, mention this forum )
the T6.1 needs a software update to correct a known software issue
