No lights in front cab?
CaliCrazy
CaliCrazy
Hi, any advice please? None of the lights work in the front cab area: the ones next to the sunglasses compartment and also the lights behind the sun visor. Could it be a fuse? The van has just come back from the van centre after a small run in with a bollard, so wondering if they've done something as they worked before.
Well have you checked the fuses?
If the sunvisor and the interieur lights are out could well be fuses...
Are you sure the switch on top near the rear mirror is "on"?
Cabin fuses are located underneath the dash / gearstick , yours is a 2012 RHD SE ?
Yes it's a 2012 RHD. Do u know which fuse it would be? Thanks
There is a diagram of the fuses in the download section
I take it you have to be a VIP member to download it?
It's written on the inside of the fuse box lid !!
Lol! I can hear you sighing and shaking your head Sidepod! I'm a bit useless with the technical side of the Cali! I'm more suited to matching cushions and making bunting!
Does engine have be running for reading lights to work on cali T6.1 ?
Or just key in ignition turned once??
Got key in ignition turned once don't work , or do have switch outside sidelights on as well for for them to work ??
Do your step lights work? Those at the feet left, right and sliding door?
