No power to any socket
G
Gavem
Beds
T5 SE 174
Hi there lovely people. Newbies here. So be gentle. We’re about to go on first long trip to Cornwall in our (new to us) 2007 cali T5 se.
None of the sockets have any power. Breakers are both ok. I’m guessing this is a fuse situation? Are they under the passenger seat? Can’t make head not tale of the diagram. The socket in the cab would be on a separate fuse? Is that correct? Any guidance here would be a wonder. Or any other checks/tips I could try?
Cheers
Gavin
Daft question but are you plugged in to the mains? Assuming you mean 13amp sockets when you say sockets, these won’t be live unless you are connected to shore power……
Also remember that the socket under the drivers seat is limited to around 300 watts and apparently it's a square wave so don't charge your toothbrush on it!
Ah, just seen, you are a T5 so my information might be incorrect.
BTW :welcome
150W for older 6.1's, T6 and before. The 300W ones have a flat wave so (apparently) ok. The inverter socket will work off EHU as long as the leisures not flat, but the kitchen socket not. If they are on EHU the first check I think would be the cube fuse above the leisure battery.
